there’s a problem with installing Piwik 1.0 on my web server. After uploading the current package files I navigated to my installation location: Firefox and Internet Explorer are showing blank pages. It seems that no content is leaving the web server.
There are no error lines in the browsers, in the logs - nowhere. Displaying and reporting errors is enabled.
So I tried debugging the problem by shifting
echo "Here I am";
through the lines of index.php.
The following code block doesn’t generate any output:
echo "Here I am";
Problem solved: Testing version 0.4.6 showed an error message: SPL extension is missing! By adding this extension to PHP version 1.0 is working without problems.
I have the same symptoms but have narrowed it down slightly:
If I do a clean unzip of latest.zip, I can access the first page. After clicking NEXT I get a blank page. I compared a before and after on the directory, and found that if I delete the core/lic.log that is created, I can access another page.
Then, after another page, it creates the log again, and once again I get a blank page. No errors in apache error logs, no errors on screen. Every time I delete the lic.log, I can get to another page.
