That seemes to be the default-way for a pikik-installation. But to realize
handling different Versions there are allways different Versions of my
Website in different DocRoot-Folders:
… and every time a programmed an update for www.example.org i first
let the domain preview.example.org point to the updated version (in
the example to folder:
/srv/www/example_03/
… and after testing the new version i let the domain www.example.org
pont to this folder.
Because i don’t want to update the running piwik-folder also I would like
to install piwik not into DocumentRoot-Folder but in another Folder an
the Server under:
thank you for your tipp. i’de found tha t yet and insallend the plugin HttpAuthLogin.
First a had the problem, that my login didn’t work anymore, but after creating
.htaccess and .htpasswd based on the example and then reloading the server
displayed it’s login-dialoge and I could login and the piwik-startpage was loaded.
but do need the plugin for what I want to do, anyhow?
seems as not:
i disabled the plugin. after that the login/logout worked like before
activating. the tracking into htassess-proteced piwik-directory seems
to work. though i didn’t login to the piwik-directory the request seems
to be tracked!
the installation to the .htaccess protected folder under config.example.org
works. i just adepted the .htaccess-file to allow request for piwik.
my new problem ist, that a part of my website are https-requests. the generated
piwik-tag trys to call config.example.org per https and that doesn’t work, because
there config.example.org is not ssl-certified.
