After successful installation, not even a single image is displayed. How i can correct this?
My guess is that it’s not a problem of image, but a problem of css.
I think your problem may be related to this one : 301 Moved Permanently
If it is the case, the solution would be Troubleshooting - Analytics Platform - Matomo
Thanks ! It’s solved with
[Debug]
disable_merged_assets = 1
Great!
Happy to be able to help you.
(You don’t tag your posts as [Solved] in this forum I think, why not?)
