I use a win2012 server with matomo 。 IIS8 with PHP7.2 MySQL5.5 。one website is working well。
First time install:download matomo from matomo.org,unzip the package in C:/www/piwik …IIS make a new website ,choose C:/www/piwik ,default AppPoll ,connect as Administrator。
It just tell me that 500
Error in Matomo: Matomo couldn’t write to some directories (running as user ‘iis apppool\defaultapppool’).Try to Execute the following commands on your server, to allow Write access on these directories:cacls C:\www\piwik\tmp /t /g iis apppool\defaultapppool:f If this doesn’t work, you can try to create the directories with your FTP software, and set the CHMOD to 0755 (or 0777 if 0755 is not enough). To do so with your FTP software, right click on the directories then click permissions.After applying the modifications, you can refresh the page.If you need more help, try Matomo.org.
