I am currently using the http api to track my react tool. I can do my post request to matomo with no issue everything seems to work fine I keep seeing each request in matomo live feed. The only issue I have is that my data isn’t saved. What I mean by saved ? Is that on my site, my entry page table is empty, and when I try to look in the events to see the event I push I don’t see them. I don’t understand what I am missing in my post request so that I can see all my data. I cannot use the javascript tracking client because it is already use in the same project for a other site and even if I add a new tracker my data it still push to the other site and I don’t want to.
Basically in my POST request I provid the following; (anything with a $ mean that is a variable)
rec:‘1’
apiv:‘1’
idsite:‘80’ (good idsite)
action_name:‘test’
url:’$url’
get_ms:1000
pv_id:‘test12’
h:’$Hour’
m:’$Mins’
s:’$Sec’
uid:’$user’
My request is fine because i have a 200 return and also I see the action in the live feed.
Post request for an event params (same as the previous) :
e_c:‘TestCategory’
e_n:‘TestName’
e_a:‘TestAction’
e_v:1
Am I missing something in my POST requests ?
Thanks for your help
