How to use Wildcard Selector for Element Visibility Trigger?
the visibility of various HTML elements should be tracked. All elements have a specific CSS class like myclass-element-1, myclass-element-2, myclass-element-3 and so on (these classes cannot be changed).
When setting up the element visibility trigger with selection method: CSS selector and defining a specific class, the trigger works as expected.
But because of the huge amount of elements I’m trying to use a wildcard selector to match all classes starting with myclass-. I tried [class^="myclass-"] but then the trigger doesn’t execute.
Is there anything wrong with my wildcard or the specific syntax? Even any other solution to achieve the same goal would be helpful.
Thanks
I have a similar problem with classes and id:s.
Can one use regex to match css selectors in the first place?
This is a good use case. Managing each class individually isn’t practical, so a wildcard selector would definitely make the setup much easier if it’s supported.
