I may be dumb, but I do not find anything, how to make use of AnonymizeIp plugin. I do activate it and even if I set ip_address_mask_length = 1 in the general section in config.ini I could see all IPs in the visitor log.
Could anyone please advice me how to use this plugin?
Hi Kaspar,
when the Plugin is activated, the fourth number of every tracked IP address should be “0” (i.e. 123.45.67.0).
Kind regards
Michael
Hi Michael,
you’re right! I’ve overseen that. I thought that the IP is completely stripped or something.
Thanks for pointing that out
Cheers
Kaspar
