How to track Phonegap android mobile application
#1
This is Arivu Selvam Phonegap mobile application developer.i want to integrate piwik into my mobile application. please give me advice.
Thanks in Advace.
(Matthieu Aubry) #2
Please have a look at this post: How to track Mobile apps usage (clicks, phones, errors, etc.) or track software analytics - Analytics Platform - Matomo
There is a SDK for iOs: GitHub - matomo-org/piwik-sdk-ios: Piwik iOS, tvOS and macOS SDK: a Piwik tracker written in Swift
#3
I am doing some tests to check the integratation of Piwik in different platforms (HTML5+JQueryMobile,HTML5+PhoneGap,Native Android, Native iPhone).
I have sucesfully tested the HTML5, native Android and native iPhone. For Android I have develop some clases to store the tracking information at a local database if the mobile is offline, and to transmit it on next start. For iPhone I have used the existing plugin.
Do you know if there are efforts to generate an Android plugin?. I am not an expert Android developer but I could contribute. The
The integration JQuery Mobile is quite straighforward using JavaScript, but if you need some tutorial for the wiki I could also contribute.
Regards
(Matthieu Aubry) #4
@agarcia
there was a client added for ios recently: Mobile Analytics SDK: beta release of Piwik iOS SDK - Analytics Platform - Matomo
it would be very useful to have such a client for tracking Android app usage with Piwik!
(Matthieu Aubry) #5
Hello Everyone,
We have started working on the Android SDK for Piwik… and we need your help!
If you can help us with testing & reviewing the code, please write in this issue: Testing the Android SDK for Piwik · Issue #1 · matomo-org/piwik-sdk-android · GitHub
Thanks,
