Thanks for the reply Peter. I was a little worried that no one really supports Piwik in these forums.
Since I use the Piwik Tracking HTTP API I load no javascript on my site from Piwik. The reason I did it this way is to make a slightly lower footprint for users and the ability to track all bots. Therefore I don’t think that type of javascript click tracking will work. Though I have not found and reference to it and these reports are available (why are they enabled if I can’t use them???)
I do want to track external links though and there seems to be very little information about how to do this. I have setup a goals along with monitoring outlinks in the report. Nothing ever is reported.
it should “just work” - if it does not for you please create a bug report @ https://github.com/piwik/piwik/issues with a link to your website that should be tracking outlinks but isn’t
