My web host is “E:\applicationsoftware\php\wwwroot” and the piwik is located in the “E:\applicationsoftware\php\wwwroot\piwik”.so when I fllowed the “Web Cron When Your Web Host Does Not Support Cron Tasks”, put the “http://202.0.0.1/piwik/misc/cron/archive.php?token_auth=c0e024d9200b5705bc4804722636378a”,
it occured errors like this:
This script archive.php must only be executed only in command line CLI mode.
In a shell, execute for example the following to trigger archiving on the local Piwik server available at ‘localhost/piwik’
$ /path/to/php /path/to/piwik/misc/cron/archive.php localhost/piwik
what it means, and how to set the web cron.
The ability of programming is low ,Please give me a detailed guidence, Thank you very much!!
