The installation continues in spite of the error, but after the first start of piwik, a new error appears :
Fatal error: require() [function.require]: Failed opening required ‘/home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/lang/.php’ (include_path=’.:/include:/usr/local/php/lib/php’) in /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/plugins/LanguagesManager/API.php on line 114
Warning: require(/home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/lang/.php) [function.require]: failed to open stream: No such file or directory in /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/plugins/LanguagesManager/API.php on line 114
Backtrace -->
#0 Piwik_ErrorHandler(2, require(/home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/lang/.php) [function.require]: failed to open stream: No such file or directory, /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/plugins/LanguagesManager/API.php, 114, Array ([filenames] => Array ([0] => ,[1] => ,[2] => ,[3] => ,[4] => ,[5] => ,[6] => ,[7] => ,[8] => ,[9] => ,[10] => ,[11] => ,[12] => ,[13] => ,[14] => ,[15] => ,[16] => ,[17] => ,[18] => ,[19] => ,[20] => ,[21] => ,[22] => ,[23] => ,[24] => ,[25] => ,[26] => ,[27] => ,[28] => ,[29] => ,[30] => ,[31] => ,[32] => ,[33] => ,[34] => ,[35] => ),[languagesInfo] => Array (),[filename] => )) called at [(null):0]
#1 Piwik_LanguagesManager_API::getAvailableLanguageNames() called at [/home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/plugins/LanguagesManager/API.php:114]
#2 Piwik_LanguagesManager_API->getAvailableLanguageNames() called at [/home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/plugins/LanguagesManager/LanguagesManager.php:56]
#3 Piwik_LanguagesManager->showLanguagesSelector(Piwik_Event_Notification Object ([_notificationName] => TopMenu.add,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 2)) called at [(null):0]
#4 call_user_func_array(Array ([0] => Piwik_LanguagesManager Object (),[1] => showLanguagesSelector), Array ([0] => Piwik_Event_Notification Object ([_notificationName] => TopMenu.add,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 2))) called at [/home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/libs/Event/Dispatcher.php:284]
#5 Event_Dispatcher->postNotification(Piwik_Event_Notification Object ([_notificationName] => TopMenu.add,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 2), 1, ) called at [/home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/core/PluginsManager.php:532]
#6 Piwik_PostEvent(TopMenu.add) called at [/home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/core/Menu/Top.php:58]
#7 Piwik_Menu_Top->get() called at [/home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/core/Menu/Top.php:71]
#8 Piwik_GetTopMenu() called at [/home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/core/Controller.php:335]
#9 Piwik_Controller->setBasicVariablesView(Piwik_View Object ([] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/plugins/CoreHome/templates/index.tpl,[] => Piwik_Smarty Object ([template_dir] => Array ([0] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/plugins,[1] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/themes/default,[2] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/themes),[compile_dir] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/tmp/templates_c,[config_dir] => configs,[plugins_dir] => Array ([0] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/core/SmartyPlugins,[1] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/libs/Smarty/plugins),[debugging] => ,[error_reporting] => 6143,[debug_tpl] => ,[debugging_ctrl] => NONE,[compile_check] => 1,[force_compile] => ,[caching] => 0,[cache_dir] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piw…
#10 Piwik_Controller->setGeneralVariablesView(Piwik_View Object ([] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/plugins/CoreHome/templates/index.tpl,[] => Piwik_Smarty Object ([template_dir] => Array ([0] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/plugins,[1] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/themes/default,[2] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/themes),[compile_dir] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/tmp/templates_c,[config_dir] => configs,[plugins_dir] => Array ([0] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/core/SmartyPlugins,[1] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/libs/Smarty/plugins),[debugging] => ,[error_reporting] => 6143,[debug_tpl] => ,[debugging_ctrl] => NONE,[compile_check] => 1,[force_compile] => ,[caching] => 0,[cache_dir] => /home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/p…
#11 Piwik_CoreHome_Controller->getDefaultIndexView() called at [/home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/plugins/CoreHome/Controller.php:89]
#12 Piwik_CoreHome_Controller->index() called at [(null):0]
#13 call_user_func_array(Array ([0] => Piwik_CoreHome_Controller Object ([] => CoreHome,[] => 2010-07-29,[] => Piwik_Date Object ([] => 1280401298,[] => UTC),[] => 1,[] => Piwik_Site Object ([] => 1)),[1] => index), Array ()) called at [/home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/core/FrontController.php:126]
#14 Piwik_FrontController->dispatch() called at [/home/www/users/1/p/2/3/p23691/www/hotelroyalbonrepos.fr/piwik/index.php:60]
