How to force POST hit and how to configure Apache server to use data via POST
I’m considering replacing our current Analytics solution (based on Adobe Analytics) with a Matomo On-Prem solution. Before performing a POC of the various features (data collection and analysis, performance, etc.), I need to run some “technical tests.”
So, I installed and configured Matomo on a VM (based on Debian, with Apache and MariaDB) and verified that it worked correctly (by building some very simple HTML pages and inserting your JavaScript snippet).
I currently have two questions:
  1. Is it possible to force the use of the POST method (instead of the traditional GET) to send data from the browser?
  2. I imagine that using POST requires a change to the Apache configuration (for example, by enabling some Apache modules). In fact, as far as I know, data sent via POST is not logged by Apache.
    Can you help me and tell me what this change is?
Thanks in advance.
Alex
You would just need to add _paq.push([‘setRequestMethod’, ‘POST’]); prior to trackpageview. All requests should then be made with post: JavaScript Tracking Client: API Reference - Matomo Analytics (formerly Piwik Analytics) - Developer Docs - v5
