I was trying to enable userid tracking on mediawiki using matomo, but as soon as i edit the “LocalSettings.php” with below changes the visit logs stop generating:-
Can anyone help me achieving this ?
# Enabled Matomo extension
wfLoadExtension( 'Matomo' );
$wgMatomoURL = ;
$wgMatomoIDSite = "2";
$wgMatomoUsePageTitle = "true";
$wgMatomoTrackUsernames = "true";
# Enable HeadScript extension
wfLoadExtension( 'HeadScript' );
$wgHeadScriptCode = <<<'START_END_MARKER'
<!-- Matomo -->
// If user is logged-in then call 'setUserId'
// $userId variable must be set by the server when the user has successfully authenticated to your app.
if (isset($userId)) {
echo sprintf("_paq.push(['setUserId', '%s']);", $userId);
_paq.push(['trackPageView']);
(function() {
var u="";
_paq.push(['setSiteId', '2']);
g.type='text/javascript'; g.async=true; g.src=u+'matomo.js'; s.parentNode.insertBefore(g,s);
</script>
