How To enable gzip for piwik.js
(druckgott) #1
Hallo, is there any posibility to aktivate gzip for piwik.js?
If yes, how can I do this?
thx
(vipsoft) #2
This is documented in piwik/js/README.
It’s a one line in change your tracking code. e.g.,
Change:
To:
document.write(unescape("%3Cscript src='" + pkBaseURL + "js/' type='text/javascript'%3E%3C/script%3E"));
(rebornsusi) #3
hi,
If I used the " /js/index.php" - File , no more Internet Explorer (6,7,8) are counted. :S
Other Browsers work well!
Have somebody the same problem?
(vipsoft) #4
If I recall correctly, there was a bug in the proxy. Please try Piwik 1.1.
