Hi there
Could somebody advise me how to disable UTM parameters?
One client website has got UTM parameters for internal links which overwrites referral traffic, so I would like to disable all utm parameter and use mtm parameter instead.
Hi there
Hi @Ken_Irie
Did you try to add this query param in the site configuration ( > Measurables > Manage > Your site)? Not sure it will work…
Hi @heurteph-ei
Thanks for your comment, I tried it but doesn’t work.
Hi @Ken_Irie
How do you track? (MTM, basic JavaScript, log analytics, etc.)
hi @heurteph-ei
do you mean non utm traffic? we use MTM.
Hi @Ken_Irie
Then I suggest:
utm*
Thanks!
Let me try and keep you update.
