Hi team,
Please guide me on the best practises for creating a schema registry in Matomo.
Let’s suppose I want to make an event for orderCheckout, so in that case, in the schema registry, I will define the fields (blank) and validation that are required whenever this eventfires from the client side.
_paq.push([‘orderCheckout’, {“productId”: “12xc”, all keys which are defined in the schema}]);
If orderCheckout method _paq.push([‘orderCheckout’ not containing the expexted fields as per the schema, then validation must be maintain in some log files or etc.
Is there a seperate plugin which needs to be download for this ? or is inbuilt in matomo ?
Thanks
