How can I archive Segments in Matomo ?
You simply create a segment and it will be archived the next time the cronjob is running (if you have set up cron correctly) and you selected the second option in the segment settings:
As I read you want to know how to achieve a segment in Matomo.
You simply produce a segment and it’ll be archived consecutive time the cronjob is running (if you have got discovered cron correctly) and you chose the second option within the section settings called
SEGMENTED REPORTS ARE PRE-PROCESSED (FASTER, REQUIRES CRON)
