How do I activate TagManager without the admin screen? I am running a cloud-based implementation of matomo. We do not activate plug-ins via admin screen as we have multiple hosts so we typically only activate plugins via updates to plug-in library and the config.ini.php file. Will this work for TagManager?
TagManager is installed in the plugin lib. Do I activate by just adding to config.ini.php file?:
Plugins[] = “TagManager”
PluginsInstalled[] = “TagManager”
