Dear Sir or Madame,
I installed Piwik and enabled the option that I get a daily report of the visitors.
How does this cronjob (daily action) work?
Because I have no rights on my webspace to run cronjobs?
Best wishes
pileo
Dear Sir or Madame,
Best wishes
pileo
Maybe you have permission to run a WEBCRON instead? How to Set up Auto-Archiving of Your Reports - Analytics Platform - Matomo
You can use a webcron service called easycron.com to trigger the script to run and look like the tutorial at: How to set up cron job for Piwik
