Looking at a report I see about 35% of so have “unknown” listed for the device model. Matomo shows me a lot more data than GA, but is there any paid plugin or code I can use to increase matches?
The only thing I’ve come across so far is the device detector github repo.
Hi @Escond1do
You can either create some ticket in the GitHub repo you mentioned or even create a PR…
What’s a PR? I’m not familiar.
@Escond1do
PR = Pull Request (also called MR - Merge Request - in some other environments). You create a branch on the GitHub repo, do some updates in the code, then ask for merging your updates to the main code…
