i am doing the install and all the write access directorys are correct, as in a valid path.
but the last one fails and the path is actually wrong…
it comes up as /home/mysite/public_htmlconfig/
shouldn’t it be /home/mysite/public_html/config/ ?
anyone know how to fix this? i am running it on nginx and i am getting no other fails in the install setup
Hi, i have the same problem, i reinstall but still alive, have you fix it?
Thanks
Solved by downgrade to 2.13…
same as you … someone can fix it … thanks
want to use 2.14
Same Problem in 2.14.2, have someone a solution or a idea to fix this (see jpg attachment)?
Webserver is: apache and fcgi.
Install instead Piwik Version 2.14.0 without problems.
Many thanks
d8v15
6
Is this still not fixed in the new version.
I dont see a link to download 2.1.4.0 version. Where is this?
matthieu
(Matthieu Aubry)
7
Hi guys
please try this version which fixes the issue: http://builds.piwik.org/piwik-2.14.3-b1.zip
it will be released in a few days
matthieu
(Matthieu Aubry)
8
Thanks for the report. We will release 2.14.3 to address this issue very soon (next couple days)
@d8v15: older versions you find there Piwik Builds
Thank you to fix the bug (tu)
