We’ve recently upgraded our huge Piwik installation to Piwik 1.12 and activated the Device Detection feature. Turns out that enabling the plugin will on-demand adding fields within the database. It was defently not nice while our database is nearly 1 TB in size with automatic deletion enabled (realy a huge installation). So after the planned shutdown of two hours for the upgrade we’ve another outage of 2 hours because of plugins actions.
Another problem is that after upgrading to 1.12 our dedicated database server (2 processors with 8*2 core each) is permanently hitting a load of 24 (was 5 with 10 at peaks). May caused by the Device Detection, may caused by Piwik itself. Tracking mostly comes through but the admin/report interface is nearly unusable (database connection timeout, too many connections, etc.).
I’m afraid that disableing Device Detection could again change the database structure so we have another outage.
Can you give me any hints? Will Device Detection change the database structure again?
I just have disabled the Device Detect plugin on the whole Piwik-Web-Cluster (we’ve another Piwik-DB-Cluster). Hope this helps, see ya in about one day or so.
Edit: May be point of interest: DevicesDetection version 1.12-b6 (which comes with Piwik 1.12 stable) - yes it’s a beta… but the reports are accurate
Hi matt. I am sorry but my supervisors have decided to do not let me reenable DeviceDetection. So I can not provice you with any further details you may need
