Hi, we’re developing a React Native app and previously used the native iOS and Android SDKs. Anyone can point us in the right direction for the correct libraries to use for our React Native app?
I don’t know of any finished React Libraries, but this should point you in the correct direction:
https://developer.matomo.org/guides/spa-tracking
(I just noticed you mean React Native. I am not that familiar with it, but as long as it is using JS and can make HTTP requests, it should work)
Appreciate it - will take a look and see if it can works. Was really looking out for finished React Native libraries… but still can’t find any…
