Hello out there I would be very pleased if someone could help me with the Matomo/Piwik API. I want to display the Actions->Pages Tree as JSON or XML, but I don’t have a clue how to accomplish that.
Thanks for your help and have a nice day! Speed Test Scrabble Word Finder
You can read through the API documentation, but there is an even easier way:
Click on the icon below the report and you see a popup that helps you with that.
PS: In case you are not using the latest version of Matomo, I’d recommend you to update.
