Help with importing logs
#1
Hi.
I’m a bit new to Piwik and I’m trying to import a log to my localhost server using the ‘import_logs.py’ and I continue to receive the same error:
Traceback (most recent call last):
File “/var/www/piwik/misc/log-analytics/import_logs.py”, line 1718, in
config = Configuration()
File “/var/www/piwik/misc/log-analytics/import_logs.py”, line 570, in init
self._parse_args(self._create_parser())
File “/var/www/piwik/misc/log-analytics/import_logs.py”, line 560, in _parse_args
self.options.piwik_token_auth = self._get_token_auth()
File “/var/www/piwik/misc/log-analytics/import_logs.py”, line 613, in _get_token_auth
credentials = open(filename, ‘r’).readline()
IOError: [Errno 2] No such file or directory: ‘/var/www/piwik/tmp/cache/token.php’
Can anybody help me?
Thank you in advance :slight_smile:
(Matthieu Aubry) #2
Can you add -ddd to the command used, and then paste full command used and output (After removing any TOKEN_AUTH= ) here?
#3
appears to be something with the config.ini.php - on update it’s missing the superuser section per my diff
i added back the superuser section, but that’s still yielding the same error
please advise… still messing around with it - might just rerun the installer
2014-03-09 22:24:30,769: [DEBUG] Accepted hostnames: all
2014-03-09 22:24:30,770: [DEBUG] Piwik URL is: http://192.168.0.1/piwik/
2014-03-09 22:24:30,770: [DEBUG] No token-auth specified
2014-03-09 22:24:30,770: [DEBUG] No credentials specified, reading them from "/var/www/html/piwik/config/config.ini.php"
File “/var/www/html/piwik/misc/log-analytics/import_logs.py”, line 1724, in
File “/var/www/html/piwik/misc/log-analytics/import_logs.py”, line 576, in init
File “/var/www/html/piwik/misc/log-analytics/import_logs.py”, line 566, in _parse_args
File “/var/www/html/piwik/misc/log-analytics/import_logs.py”, line 619, in _get_token_auth
IOError: [Errno 2] No such file or directory: ‘/var/www/html/piwik/tmp/cache/token.php’
#4
ahh… looks like it’s just perms - previously it could be run as any user and it seems now it cannot - i guess it now needs to write something to the install dir, so you need to run as root or the web owner
#5
Hello everyone.
Thank you in advance for the help. Apparently it has something to do with this new version of Piwik. I removed the new version, installed an old one, and everything worked like a charm.
Perhaps this new version of Piwik needs to be ‘tuned’ in some aspects, specially this one.
But once again, thank you so kindly for your help.
Best regards,
Yakare
#6
if you do not have token auth, please add two parameters, --login --password, following with import_logs.py. they are users which could login the piwik.
#7
Luty
Thanks for the feedback, but what is the correct syntax for the addition.
just add --login piwik --password abcd
or --login=piwik --password=abcd
this is not clear.
Also what do you mean by token auth. My piwik user has sudo rights. Is this something that needs to b generated?
Thanks
Lawrence
