I just tried to install Piwik, and after I fill the SQL’s form, but I get this error :
Test SQL failed to execute: INSERT INTO piwik_test_table (value) VALUES (123) Error: SQLSTATE[HY000]: General error: 2014 Cannot execute queries while other unbuffered queries are active. Consider using PDOStatement::fetchAll(). Alternatively, if your code is only ever going to run against mysql, you may enable query buffering by setting the PDO::MYSQL_ATTR_USE_BUFFERED_QUERY attribute.
