I’m trying to pull some data out of Piwik and the visitor log has everything I need at the moment save for the "Campaign Medium."
How can I go about adding it as a field in the csv export of the visitor log?
Hi there,
can you please create a new issue / feature request in this issue tracker: https://github.com/PiwikPRO/plugin-AdvancedCampaignReporting/issues/ ?
Done. Thanks!
