I gave Matomo on-prem and aid for the heatmap feature. However, I set bunch pf pages up and am not seeing anything, just messages like this:
What am I doing wrong? I must be missing something obvious as it is the same for all of them.
Hi there,
If Matomo is unable to capture the screenshot automatically, there should be an option to ‘manually’ capture this.
You can find that option when editing your heatmap.
More information on this method can be found here - https://matomo.org/faq/heatmap-session-recording/how-to-capture-the-initial-heatmap-snapshot-manually/
Alternatively when viewing your web page, you can append to the pageURL &pk_hsr_forcesample=1 (or #pk_hsr_forcesample=1 depending on the site) to try and force a screenshot to be taken.
Thanks Jason,
I tried all of this and things are still not working. Any other suggestions?
Could you email shop@matomo.org directly? The support team will be able to help you there.
I’ve been running into some similar issues with heatmaps not generating lately, so this breakdown is super helpful. It’s usually one of those small settings that’s easy to overlook but makes all the difference once it’s dialed in.
Hello @JasmineCasper Glad it helped! Yeah, it’s almost always one of those subtle config details—once it’s sorted, everything just clicks back into place. Let me know if you run into anything else.
