i’m using 0.2.28 and i tryed to add some goals but they are not shown… but in database they exist.
after creating a new goal i’m redirected to dashboard, dont know if it’s normal…
regards
regards
Ok i got it, the sql query’s in goals api uses “?” as a placeholder but it’s only replaced with one char of idsite or idgoal.
if i add a goal for page with id 3 it’s also shown on all sites with id 30, 31, 32, 33, 34, 35 and all goals i add to an site with id 20, 21, 22 is only visible on site with id 2…
regards
I wasn’t able to replicate the bug - are you sure there is an issue?
