Goal conversion not working
I set up several goals, which are considered outlinks from my home page, that are not recording as goal conversions. Piwik records the outlink okay but is not recording as a conversion to the goal I set up.
“By default, Goals in Piwik are defined as “matching” parts of the URL (starts with, contains, or regular expression matching). You can also by default track goals for given page views, downloads, or outlinks clicks.”
The goal I’ve set is ‘exact’ match URL. What am I missing?
Thanks in advance…
Can you maybe try a matching URL Goal definition, and see if it works better?
Thanks for the reply - I will try that…
