What is the impact if I anonymize visitor’s IP? Specially for the geolocalisation?
Thanks in advance,
Marc.
Thanks in advance,
Marc.
Geo Location should still work, with anonimized IP, as it will replace the anonmized bytes by “1” and try to geo locate this
hi matt,
unfortunately this doesn’t work for me. some facts:
any idea what’s going wrong? does the apache module or the maxmind database behind it not like 112.151.21.1?
cheers
Matt,
So, does it mean there are no impact at all on the data with anonimized IP?
Thanks.
The impact is that it’s not as correct as before. The IP address is anonymized but the last octet is then replaced with 1 to make geolocalisation possible. Its as near as it can get with anonymization ;).
@marc: as i said above, unfortunately for us geo locations are completely off when using ip anonymisation. we tested with ips in south korea, germany and belgium. in all 3 cases locations were not reliable. your mileage may vary.
but i suspect something is buggy in either piwik or the location provider database. could anyone comment on this?
meinhard can you please send us the 3 IPs you have tested, and which anonimized IP you have tested? you can use: http://geoiptool.com/ for the tests? thanks!
