I’ve just installed piwik for my website www.hafdal.dk, which is running on Joomla 3. I have a plugin for the piwik script, which appears to be working (the code is visible in my website), but still Piwik is not tracking any visits.
This is not the first time I have installed Piwik, I have done it several times on other websites without any issues. This time, I have tried to use both my joomla database as well as a completely fresh database without success.
I did get some “cookies” errors during installation, but switched browsers and deleted the tables that had been created before the error so in the end I got a Piwik installation that looks okay, but is not registering any visits.
I experience the same problem: installation showed the cookie error several times (although phpinfo shows session cookies activated) and I can access the dashboard etc. but it doesn’t log any activities…
when I look at the mysql database most tables are empty (for example all piwik_log_ - only piwik_log_action has a lot of entries…).
Now I tried it with several versions of the Tracking Code… also the image… but no records.
What to do? is there an older piwik version I can install?
I see this post is a couple of months old, but there is no resolve posted.
I have the same issue.
I actually upgraded to 2.4.1 and the system shows no updates available.
Yet, I have NO tracking information. It’s been a couple of weeks that the site was “supposed” to be tracking.
I’ve checked the tracking code and can’t see anywhere that would indicate a problem.
I’m using the “plugin” within Joomla for Piwik, and that’s not working.
The code is there, but I get no stats.
