Hello
It’s the first time I try to install Piwik but I received two message in the second page
1-Pdo_Mysql extension
You need to enable the PDO and PDO_MYSQL extensions in your php.ini file.
On a windows server you can add the following lines in your php.ini
extension=php_pdo.dll
extension=php_pdo_mysql.dll
On a Linux server you can compile php with the following option --with-pdo-mysql In your php.ini, add the following lines
extension=pdo.so
extension=pdo_mysql.so
More information on the PHP website.
2 -Memory limit
32M On a high traffic website, the archiving process may require more memory than currently allowed.
See the directive memory_limit in your php.ini file if necessary.
I don’t know what i need do to resolve it!!
somebody can help me?
Thanks
