Filter problem for Campaign Name
Hi to all,
I’m noticing a problem with the text filter in the Campaigns section.
If I enter text to filter a campaign by name, only 3 out of 5 lines appear.
Anyone have any idea why? It’s a bug?
Hello @Dret
Could you please share to us a screenshot of the issue and we’ll try to replicate it?
Here two screenshot explaining the issue:
The fisrt is the complete list of Campaign “Name + Keyword” value:
Here the same list after “filtering” by keyword “roma”.
The result shows only some value (and not other) of the previous list that contain the text “roma” (es. the first line, with 33 visits, is not showed):
Seems to be a bug?
Thanks for supporting!
Just so we’re on the same page, would you be able to quickly confirm you’re using the latest Matomo version and can still reproduce the issue there?
If you can’t reproduce it then we’re happy to say this bug was fixed in the newest version!
If you can reproduce it then it’d be great if you could create a bug report on our issue tracker here:https://github.com/matomo-org/matomo/issues
This is so we have it noted down as something to investigate in the next releases.
In order to help us deal with it effectively, please make sure your bug report contains the list of steps to reproduce the issue, and explains the behaviour you get versus what you expected to see.
We’re looking forward to hearing from you or seeing your bug report on GitHub.
