Filter Page URLs by Segments
Same issue here - I want to be able to segment pageviews by language (e.g. URL contains /en/ vs. URL contains /fr/) but the current segment functionality does not support this.
Is there a workaround to get this desired behavior in the Matomo UI? @PeaceSfiSh you mentioned “the search function”? Mind explaining how to achieve this?
Thanks all.
Now this is totaly usless.
I am one of the the user suffering the same issue…we just simply want to collect the figures about some groups of URLs through creating a segment but now it will return something we don’t need. Even the suggested way which using the Goal to do the similar thing, i do believe it is just a work around and be honest i think it is not make sense. So what can we do now? is it possible to have a patch so that it can be back to the original “normal” behaviour? Many thanks.
@renet @plyleung Look at this config param. It brings back the old behaviour.
https://github.com/matomo-org/matomo/issues/15438#issuecomment-663198958
