# Errors
- Error Matomo System Check: Failed to run Matomo system check. (WP DB Error: Ошибка базы данных WordPress: Обработка значения для следующего поля не удалась: name. Значение может иметь избыточную длину или содержать неверные данные.)
Matomo
- Matomo Plugin Version: 5.0.5
- Config exists and is writable.: Yes (“$abs_path/wp-content/uploads/matomo/config/config.ini.php” )
- JS Tracker exists and is writable.: Yes (“$abs_path/wp-content/uploads/matomo/matomo.js” )
- Plugin directories: Yes ([{“pluginsPathAbsolute”:“$abs_path/wp-content/plugins/matomo/plugins”,“webrootDirRelativeToMatomo”:“…/plugins”}])
- Tmp directory writable: Yes ($abs_path/wp-content/cache/matomo)
- Matomo Blog idSite: 0
- Matomo Install Version: 5.0.5 (Install date: 2024-04-22 18:06:45)
- Upgrades outstanding: No
- Upgrade in progress: No
Endpoints
- Matomo JavaScript Tracker URL: ($site_url/wp-content/uploads/matomo/matomo.js)
- Matomo JavaScript Tracker - WP Rest API: ($site_url/wp-json/matomo/v1/hit/)
- Matomo HTTP Tracking API: ($site_url/wp-content/plugins/matomo/app/matomo.php)
- Matomo HTTP Tracking API - WP Rest API: ($site_url/wp-json/matomo/v1/hit/)
Crons
- Server time: 2024-04-22 16:29:46
- Blog time: 2024-04-22 19:29:46 (Below dates are shown in blog timezone)
- Sync users & sites: Next run: 2024-04-23 18:08:02 (22 час 38 мин) ( Last started: 2024-04-22 18:09:26 (-1 час 20 мин). Last ended: Unknown. Interval: daily)
- Archive: Next run: 2024-04-22 20:06:46 (37 мин 0 сек) ( Last started: 2024-04-22 19:16:57 (-12 мин 49 сек). Last ended: 2024-04-22 19:16:57 (-12 мин 49 сек). Interval: hourly)
- Update GeoIP DB: Next run: 2024-05-22 18:07:40 (29 дн. 22 час) ( Last started: 2024-04-22 18:08:59 (-1 час 20 мин). Last ended: 2024-04-22 18:09:26 (-1 час 20 мин). Interval: matomo_monthly)
Matomo Settings
- Track mode: default
- Track ecommerce: Yes
- Track codeposition: footer
- Track api endpoint: default
- Track js endpoint: default
- Version history: 5.0.5
- Core version: 5.0.2
- Last tracking settings update: 1713798460
- Last settings update: 1713798460
Logs
WordPress
- Home URL: $site_url
- Site URL: $site_url
- WordPress Version: 6.5.2
- Number of blogs: 1
- Multisite Enabled: No
- Network Enabled: No
- WP_DEBUG: No
- WP_DEBUG_DISPLAY: Yes
- WP_DEBUG_LOG: No
- DISABLE_WP_CRON: -
- FORCE_SSL_ADMIN: Yes
- WP_CACHE: No
- CONCATENATE_SCRIPTS: -
- COMPRESS_SCRIPTS: -
- COMPRESS_CSS: -
- ENFORCE_GZIP: -
- WP_LOCAL_DEV: -
- WP_CONTENT_URL: $site_url/wp-content
- WP_CONTENT_DIR: $abs_path/wp-content
- UPLOADS: -
- BLOGUPLOADDIR: -
- DIEONDBERROR: -
- WPLANG: -
- ALTERNATE_WP_CRON: -
- WP_CRON_LOCK_TIMEOUT: 60
- WP_DISABLE_FATAL_ERROR_HANDLER: -
- MATOMO_SUPPORT_ASYNC_ARCHIVING: -
- MATOMO_ENABLE_TAG_MANAGER: -
- MATOMO_SUPPRESS_DB_ERRORS: -
- MATOMO_ENABLE_AUTO_UPGRADE: -
- MATOMO_DEBUG: -
- MATOMO_SAFE_MODE: -
- MATOMO_GLOBAL_UPLOAD_DIR: -
- MATOMO_LOGIN_REDIRECT: -
- Permalink Structure: /%postname%/
- Possibly uses symlink: No
- Upload base url: $site_url/wp-content/uploads
- Upload base dir: $abs_path/wp-content/uploads
- Upload url: $site_url/wp-content/uploads/2024/04
- Custom upload_path:
- Custom upload_url_path:
- Compatible content directory: Yes
- WP_Filesystem Initialized: Yes
WordPress Plugins
- Advanced Custom Fields PRO: 6.0.6
- Cyr-To-Lat: 5.5.2
- Duplicate Page: 4.5.2
- Matomo Analytics - Ethical Stats. Powerful Insights.: 5.0.5
- SVG Support: 2.5.5
- WebP Express: 0.25.6 (Network enabled)
- WP Fastest Cache: 1.1.6
- WP phpMyAdmin: 5.2.1.12
- Active Plugins: 8 (advanced-custom-fields-pro-master:6.0.6 cyr2lat:5.5.2 duplicate-page:4.5.2 matomo:5.0.5 svg-support:2.5.5 webp-express:0.25.6 wp-fastest-cache:1.1.6 wp-phpmyadmin-extension:5.2.1.12)
- Theme: comfortgroup (comfortgroup)
Server
- Server Info: Apache/2.4.55 (Unix)
- Apache AddHandler support: Supported
- PHP OS: Linux
- PHP Version: 7.4.33
- PHP SAPI: apache2handler
- PHP Maxmind DB extension: Not loaded
- PHP Error Reporting: 0 After bootstrap: 0
- PHP Found Binary: /usr/bin/php -q
- Timezone: UTC
- WP timezone: +03:00
- Locale: ru_RU
- User Locale: ru_RU
- Memory Limit: 6G (At least 128MB recommended. Depending on your traffic 256MB or more may be needed.)
- WP Memory Limit: 6G
- WP Max Memory Limit: 6G
- Timezone version: 2024.1
- Time: 1713803386
- Max Execution Time: 600
- Max Post Size: 1047527424
- Max Upload Size: 1047527424
- Max Input Vars: 10000
- Disabled PHP functions: No
- zlib.output_compression is off: Yes
- Curl Version: 8.5.0, OpenSSL/1.1.1w
- Suhosin installed: No
PHP cli
- PHP cli Version: 7.4.33
- MySQLi support: ok
Database
- MySQL Version: 5.7.21
- Mysqli Connect: Yes
- Force MySQL over Mysqli: No
- DB Prefix: wp_
- DB CHARSET: utf8mb4
- DB COLLATE:
- SHOW ERRORS: No
- SUPPRESS ERRORS: No
- Uses Socket: No
- Uses IPv6: No
- Matomo tables found: 37
- DB tables exist: Yes
- Matomo users found: 1
- Matomo sites found: 0
- Required permissions: OK
Browser
- Browser: (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:124.0) Gecko/20100101 Firefox/124.0)
- Language: ru-ru,ru,en-us,en
