I have just started using Piwik end-December. So far: Perfectly. Thanks.
I am trying, now, to use the “Export TSV” for the Pages report. It works - for the “high level” folders, but for the lower folders the data is not exported (I may have worded this incorrectly… but, I give it a shot below)
Forder1
Folder2
In folder2 are htm’s that I see the reports visually/on the display. When I export, I do NOT see the reports for htm’s that exist in the sub-folder Folder2
Any hints would be appreciated.
Regards,
Dave Shogren
Copy the URL and add &expanded=1 to it,
or you can also try &flat=1
Well… I have no idea what you mean about copying the URL. I have many htms in the subfolder… and if you mean modifying the Piwik code within the htm style, I will pass on doing that. No comeback necessary…
Close this item out. I will go on the assumption that the export of multi-level folders is not possible and live with that. I have been doing such, living with the now-demised GoDaddy statistics - and, Piwik fits fine so far even without an exported file.
Ignore this item on the forum. I probably would end up wasting your time (being such a novice with Piwik).
Thank you again and
Regards,
Dave Shogren
What i meant was to copy the TSV download URL (instead of clicking on it, do right click >copy url) then add the parameter. We’d like to make it more user friendly in the future!
Ok!
I did not quite see how to copy URL and, in turn, modify it by adding a parameter – but, I DID spot the “Make it Flat” option to the right.
Excellent.
That will work for me.
I appreciate your taking the time to stick with me. Close this item, with a Happy User.
Regards,
Dave Shogren
