LaurentN
(Laurent)
October 7, 2022, 3:53pm
1
Hi guys !
I’m sorry to post in the Forum for a subject that may seem quite obvious… but I’m struggling, and I can’t find an answer in existing posts…
Here’s the deal :
I’m simply trying to build a simple Custom Report with :
And I cannot find those metrics in the list… Is there another terminology used ? (I’m using Matomo in French… maybe a translation issue ?)
Thanks a lot for any tip !
If I remember well, in the past, there were some translations problems with Custom Reports… I don’t remember if it is still the case (Which versions of Matomo / Custom Reports do you use?)
Maybe you could try change your user language and see if the problem is still there…
Personally, Version: 4.3.1
Total Number of Events → Hits
Number of Unique Events → Noms D’évènementUnique
If this doesn’t work, and because it’s about some premium plugin, don’t hesitate to contact the support team by email.
V.K
(V)
October 12, 2022, 7:42pm
3
Hi @LaurentN thanks for reaching out.
You can use the Dimension “Event Name”
And the following Metrics:
“Total Events”
“Unique Event Names” OR “Unique Event Actions”
Hope this helps.
LaurentN
(Laurent)
October 14, 2022, 10:39am
4
Hi Varun,
Thanks for your suggestion.
I tried it … but I really have a doubt ;
Let me share what I observe :
On the Custom Report I’ve prepared according to your suggestion I get :
And when I just go to the standard Behaviour / Events report, for the same Events I get :
So I’m really confused… and having doubts…
Basically the custom report I’m trying to get is the same as the standard, just with an extra condition/filter.
So I should get the the same figures…
Thanks for any idea
best rgds
LaurentN
(Laurent)
October 14, 2022, 10:41am
5
Hi Philippe,
I’m on the Cloud version.
… It’s very confusing.
I was thinking this custom report could be done in a few clicks… I wasn’t expecting to struggle
V.K
(V)
October 16, 2022, 8:27pm
6
Hi @LaurentN as this is in relation to Matomo Cloud. Could you please get in touch via support@matomo.cloud
Please also review: https://matomo.org/faq/reports/create-and-analyse-custom-reports/#report-filter
To learn more about Filters in Custom Reports.
LaurentN
(Laurent)
October 21, 2022, 8:12am
7
Hi @V.K
I will indeed get in touch with the support ; but I beleive that this subject, and I hope, it’s solution would be interesting for all the forum users.
I’ll let you know what they say.
best regards
Laurent
@LaurentN I faced the same problem today.
Just in case if you or someone else struggles with inconsistent numbers of events: use the “HITS” metric.
see https://matomo.org/faq/custom-reports/how-do-i-add-the-metric-events-to-a-custom-report/
goochj03
(Jason Gooch)
February 20, 2025, 7:00am
9
This is correct, you would need to use the ‘hits’ metric to get the correct amount of events that have been fired in a custom report.
