Hello, I have this error at every Piwik page, this is first page - instalation. I had this same error with PHPMV, but i set SMARTY DEBUG = true in config.inc.php in PHPMV root and it was ok. But this ins’t working on Piwik.
I think that reason of this error is php setting which set encoding to utf-8 for mbstring functions, and it rewrites basic functions like strlen to mb_strlen, so strlen is in fact mb_strlen.
php_value mbstring.internal_encoding "utf-8"
php_value mbstring.func_overload 7
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="www.w3.org/1999/xhtml">
<head>
<title>Piwik › Instalace</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7" />
<link rel="stylesheet" type="text/css" href="themes/default/common.css?piwik=0.5.4" />
<link rel="stylesheet" type="text/css" href="libs/jquery/themes/base/jquery-ui.css?piwik=0.5.4" />
<link rel="stylesheet" type="text/css" href="themes/default/styles.css?piwik=0.5.4" />
<script type="text/javascript" src="libs/jquery/jquery.js?piwik=0.5.4"></script>
<script type="text/javascript" src="libs/jquery/jquery-ui.js?piwik=0.5.4"></script>
<script type="text/javascript" src="libs/jquery/fdd2div-modified.js?piwik=0.5.4"></script>
$(document).ready( function(){
$('#toFade').fadeOut(4000, function(){ $(this).css('display', 'hidden'); } );
$('input:first').focus();
$('#progressbar').progressbar({
value: 0
</script>
<style>
</style>
</head>
<body>
<div id="main">
<div id="content">
<div id="logo">
<span id="title">Piwik</span> <span id="subtitle"># Open Source Web Analytics</span>
</div>
<div style="float:right" id="topRightBar">
<span class="topBarElem" style="padding-right:70px">
<span id="languageSelection" style="display:none;position:absolute">
<form action="index.php?action=saveLanguage" method="get">
<select name="language">
<option value="cs">Česky</option>
<option value="be">Беларуская</option>
<option value="bg">Български</option>
<option value="ca">Català</option>
<option value="da">Dansk</option>
<option value="de">Deutsch</option>
<option value="el">Ελληνικά</option>
<option value="en">English</option>
<option value="es">Español</option>
<option value="et">Eesti keel</option>
<option value="fi">Suomi</option>
<option value="fr">Français</option>
<option value="gl">Galego</option>
<option value="hu">Magyar</option>
<option value="it">Italiano</option>
<option value="ja">日本語</option>
<option value="ko">한국어</option>
<option value="lt">Lietuvių</option>
<option value="nb">Norsk (bokmål)</option>
<option value="nl">Nederlands</option>
<option value="pl">Polski</option>
<option value="pt">Português</option>
<option value="ro">Română</option>
<option value="ru">Русский</option>
<option value="sk">Slovensky</option>
<option value="sq">Shqip</option>
<option value="sr">Srpski</option>
<option value="sv">Svenska</option>
<option value="th">ไทย</option>
<option value="uk">Украї�<script language="javascript">
$(document).ready(function() {
$("#languageSelection").fdd2div({CssClassName:"formDiv"});
$("#languageSelection").show();
$("#languageSelection ul").hi<script type="text/javascript">
$(function() {
if (document.location.protocol === 'https:') {
$('p.nextStep a').attr('href', $('p.nextStep a').attr('href') + '&clientProtocol=https');
</script>lue="zh-cn">简体中文</option>
<option value="z@@@SMARTY:TRIM:SCRIPT@@@
</select>
<input type="submit" value="go"/>
</form>
</span>
</span>
</div>
<div class="both"></div>
<div id="generalInstall">
<ul>
<li class="actualStep">Vítejte!</li>
<li class="futureStep">Kontrola systému</li>
<li class="futureStep">Database setup</li>
<li class="futureStep">Database check</li>
<li class="futureStep">Vytváření tabulek</li>
<li class="futureStep">Hlavní nastavení</li>
<li class="futureStep">Nastavit WWW sídlo</li>
<li class="futureStep">JavaScript tag</li>
<li class="futureStep">Gratulujeme</li>
</ul> </div>
<div id="detailInstall">
<h1>Vítejte!</h1>
<p>Piwik je open source program pro analýzu webu, pomocí kterého můžete jednoduše získat informace, které chcete od vaších návštěvníků.</p><p>Tento proces je rozdělen to 9 jednoduchých kroků a zabere přibližne 5 minut.</p>
<p class="nextStep">
<a href="index.php?action=systemCheck">Další »</a>
</p>
</div>
<br/>
<br/>
<h3>Stav instalace</h3>
<div id="progressbar"></div>
0 % hotovo
</div>
</div>
</body>
</html>
