Hi PIWIK,
we have an issue when running import_logs.py as cronjob. line in shell script:
/var/www/html/piwik/misc/log-analytics/import_logs.py -d --login=root --password=hmbtghmbtg --url=http://localhost/piwik $logfile --idsite=1 --recorders=4 --enable-http-errors --enable-http-redirects --enable-static --enable-bots &>>$PIWIK_LOG
Error message from import-logs.py: 2014-11-10 16:58:02,396: [DEBUG] Accepted hostnames: all
2014-11-10 16:58:02,396: [DEBUG] Piwik URL is: http://localhost/piwik
2014-11-10 16:58:02,396: [DEBUG] No token-auth specified
2014-11-10 16:58:02,396: [DEBUG] Using credentials: (login = root, password = xxxxx)
2014-11-10 16:58:02,410: [DEBUG] Error when connecting to Piwik: HTTP Error 404: Not found
2014-11-10 16:58:04,422: [DEBUG] Error when connecting to Piwik: HTTP Error 404: Not found
2014-11-10 16:58:06,431: [DEBUG] Error when connecting to Piwik: HTTP Error 404: Not found
Fatal error: Not found
When running the same script from terminal it works fine.
Do you have any idea?
Kind regards
hullrich
Hello Matt,
unfortunately changing command to:
/var/www/html/piwik/misc/log-analytics/import_logs.py -d --login=root --password=xxxxxxx --url=localhost/piwik/ /home/hmbtg-analyse/bin/testPiwik.log --idsite=1 --recorders=4 --enable-http-errors --enable-http-redirects --enable-static --enable-bots --dry-run &>>$PIWIK_LOG
does not help.
Output when starting from terminal or manually from crontab:
2014-11-13 10:17:23,367: [DEBUG] Accepted hostnames: all
2014-11-13 10:17:23,368: [DEBUG] Piwik URL is: http://localhost/piwik/
2014-11-13 10:17:23,368: [DEBUG] No token-auth specified
2014-11-13 10:17:23,368: [DEBUG] Using credentials: (login = root, password = c4401a93dc35098941975f65fa605e05)
2014-11-13 10:17:23,409: [DEBUG] Authentication token token_auth is: e788e3b6775b364941b593c5bb7fa3b4
2014-11-13 10:17:23,410: [DEBUG] Resolver: static
2014-11-13 10:17:23,461: [DEBUG] Launched recorder
2014-11-13 10:17:23,462: [DEBUG] Launched recorder
2014-11-13 10:17:23,463: [DEBUG] Launched recorder
Output when starting automatically from crontab:
2014-11-13 10:11:07,109: [DEBUG] Accepted hostnames: all
2014-11-13 10:11:07,109: [DEBUG] Piwik URL is: http://localhost/piwik/
2014-11-13 10:11:07,109: [DEBUG] No token-auth specified
2014-11-13 10:11:07,109: [DEBUG] Using credentials: (login = root, password = c4401a93dc35098941975f65fa605e05)
2014-11-13 10:11:07,128: [DEBUG] Error when connecting to Piwik: HTTP Error 404: Not found
2014-11-13 10:11:09,563: [DEBUG] Error when connecting to Piwik: HTTP Error 404: Not found
2014-11-13 10:11:11,577: [DEBUG] Error when connecting to Piwik: HTTP Error 404: Not found
In both case URL is resolved to http://localhost/piwik/.
Do you have any other suggestions?
Cheers, Hartmut
[size=x-small][/size]Hi Matt,
we are still working on this issue that the import script fails when started automatically from crontab.
When start from shell or manually from crontab via gnome scheduler everything works fine.
The debug log information we get now is:
[size=small][u]2014-11-27 15:38:02,718: [DEBUG] Accepted hostnames: all
2014-11-27 15:38:02,718: [DEBUG] Piwik URL is: http://localhost/piwik/
2014-11-27 15:38:02,718: [DEBUG] No token-auth specified
2014-11-27 15:38:02,718: [DEBUG] Using credentials: (login = xxxx, password = xxxxxxxxxxxxxxxxx)
2014-11-27 15:38:02,731: [DEBUG] Error when connecting to Piwik: <urlopen error Piwik returned an invalid response:
Firewall Authentication
You are requesting a restricted connection limited to authenticated users only. Enter your firewall login data and press Login to authenticate on the firewall.
Firewall Authentication failed
Login was not successful. Restricted network connections are denied.
mmh, the situation is that piwik and the import script are on the same server. So there should be no network access through firewalls.
On this server the firewall is inactive:
sudo ufw status
[sudo] password for hmbtg-analyse:
Status: inactive
What do you think?
Cheers, Hartmut
