Now i’m running following command, but still facing some issues.
C:\>python "path\piwik\misc\log-analytics\import_logs.py" --debug --url=xxxxxxxxxxx/piwik
/ --add-sites-new-hosts "C:\Program Files (x86)\Apache Software Foundation\Apach
e2.2\logs\access.log" --idsite=1 --recorders=1
2016-05-10 15:05:43,288: [DEBUG] Accepted hostnames: all
2016-05-10 15:05:43,289: [DEBUG] Piwik URL is: xxxxxxxxxxxx
2016-05-10 15:05:43,289: [DEBUG] No token-auth specified
2016-05-10 15:05:43,290: [DEBUG] No credentials specified, reading them from "C:
\Program Files (x86)\Apache Software Foundation\Apache2.2\htdocs\piwik\config\co
nfig.ini.php"
2016-05-10 15:05:44,825: [DEBUG] Authentication token token_auth is: 90871c8584d
df2265f54553a305b6ae1
2016-05-10 15:05:44,825: [DEBUG] Resolver: static
2016-05-10 15:05:44,829: [INFO] Error when connecting to Piwik: HTTP Error 404:
Not Found
2016-05-10 15:05:44,829: [INFO] Retrying request, attempt number 2
2016-05-10 15:05:54,835: [INFO] Error when connecting to Piwik: HTTP Error 404:
Not Found
2016-05-10 15:05:54,835: [INFO] Retrying request, attempt number 3
2016-05-10 15:06:04,842: [INFO] Error when connecting to Piwik: HTTP Error 404:
Not Found
2016-05-10 15:06:04,842: [INFO] Max number of attempts reached, server is unreac
hable!
Traceback (most recent call last):
File "C:\Program Files (x86)\Apache Software Foundation\Apache2.2\htdocs\piwik
\misc\log-analytics\import_logs.py", line 2571, in <module>
resolver = config.get_resolver()
\misc\log-analytics\import_logs.py", line 1205, in get_resolver
return StaticResolver(self.options.site_id)
\misc\log-analytics\import_logs.py", line 1616, in __init__
'SitesManager.getSiteFromId', idSite=self.site_id
\misc\log-analytics\import_logs.py", line 1599, in call_api
return cls._call_wrapper(cls._call_api, None, None, method, **kwargs)
\misc\log-analytics\import_logs.py", line 1586, in _call_wrapper
raise Piwik.Error(message, code)
__main__.Error: HTTP Error 404 Not Found, response: <!DOCTYPE HTML PUBLIC "-//IE
TF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL /piwik// was not found on this server.</p>
</body></html>
Anyone can help me in this?
