I have a Matomo instance running for a few days. The web UI is working fine. I’m trying to setup an archive cron job. Each time I run I get the following error. Any suggestions on how to track down the issue? I’m running Matomo 3.5.0 on Ubuntu with php 7.0.30
INFO [2018-08-22 18:00:05] 2398 - Reports for today will be processed at most every 150 seconds. You can change this value in Matomo UI > Settings > General Settings.
INFO [2018-08-22 18:00:05] 2398 - Reports for the current week/month/year will be requested at most every 3600 seconds.
INFO [2018-08-22 18:00:05] 2398 - Will process 1 other websites because some old data reports have been invalidated (eg. using the Log Import script or the InvalidateReports plugin) , IDs: 1
INFO [2018-08-22 18:00:05] 2398 ---------------------------
INFO [2018-08-22 18:00:05] 2398 START
INFO [2018-08-22 18:00:05] 2398 Starting Matomo reports archiving...
INFO [2018-08-22 18:00:05] 2398 Old report was invalidated for website id 1
INFO [2018-08-22 18:00:05] 2398 Will pre-process for website id = 1, period = day, date = last52
INFO [2018-08-22 18:00:05] 2398 - pre-processing all visits
INFO [2018-08-22 18:00:32] 2398 Done archiving!
INFO [2018-08-22 18:00:32] 2398 ---------------------------
INFO [2018-08-22 18:00:32] 2398 SUMMARY
INFO [2018-08-22 18:00:32] 2398 Total visits for today across archived websites: 0
INFO [2018-08-22 18:00:32] 2398 Archived today's reports for 0 websites
INFO [2018-08-22 18:00:32] 2398 Archived week/month/year for 0 websites
INFO [2018-08-22 18:00:32] 2398 Skipped 1 websites
INFO [2018-08-22 18:00:32] 2398 - 0 skipped because no new visit since the last script execution
INFO [2018-08-22 18:00:32] 2398 - 0 skipped because existing daily reports are less than 150 seconds old
INFO [2018-08-22 18:00:32] 2398 - 0 skipped because existing week/month/year periods reports are less than 3600 seconds old
INFO [2018-08-22 18:00:32] 2398 - 1 skipped because got an error while querying reporting API
INFO [2018-08-22 18:00:32] 2398 Total API requests: 0
INFO [2018-08-22 18:00:32] 2398 done: 0/1 0%, 0 vtoday, 0 wtoday, 0 wperiods, 0 req, 26373 ms, 1 errors.
INFO [2018-08-22 18:00:32] 2398 Time elapsed: 26.373s
INFO [2018-08-22 18:00:32] 2398 SCHEDULED TASKS
INFO [2018-08-22 18:00:32] 2398 Starting Scheduled tasks...
INFO [2018-08-22 18:00:32] 2398 Scheduler: executing task Piwik\Plugins\ExamplePlugin\Tasks.myTask...
INFO [2018-08-22 18:00:32] 2398 Scheduler: finished. Time elapsed: 0.000s
INFO [2018-08-22 18:00:32] 2398 Scheduler: executing task Piwik\Plugins\CustomPiwikJs\Tasks.updateTracker...
INFO [2018-08-22 18:00:32] 2398 Scheduler: finished. Time elapsed: 0.001s
INFO [2018-08-22 18:00:32] 2398 Scheduler: executing task Piwik\Plugins\PrivacyManager\Tasks.anonymizePastData...
INFO [2018-08-22 18:00:32] 2398 SUMMARY OF ERRORS
INFO [2018-08-22 18:00:32] 2398 Error: Empty or invalid response INFO [2018-08-22 18:19:34] piwik.DEBUG: Loaded plugins:
CorePluginsAdmin, CoreAdminHome, CoreHome, WebsiteMeasurable, Diagnostics, CoreVisualizations,
Proxy, API, ExamplePlugin, Widgetize, Transitions, LanguagesManager, Actions, Dashboard,
MultiSites, Referrers, UserLanguage, DevicesDetection, Goals, Ecommerce, SEO, Events,
UserCountry, GeoIp2, VisitsSummary, VisitFrequency, VisitTime, VisitorInterest, ExampleAPI,
RssWidget, Feedback, Monolog, Login, UsersManager, SitesManager, Installation, CoreUpdater,
CoreConsole, ScheduledReports, UserCountryMap, Live, CustomVariables, PrivacyManager,
ImageGraph, Annotations, MobileMessaging, Overlay, SegmentEditor, Insights, Morpheus,
Contents, BulkTracking, Resolution, DevicePlugins, Heartbeat, Intl, Marketplace,
ProfessionalServices, UserId, CustomPiwikJs [] {"class":"Piwik\\Plugin\\Manager","request_id":6046}
[2018-08-22 18:19:34] piwik.DEBUG: /* trigger = CronArchive */ SELECT count(distinct log_visit.idvisitor)
AS `1`, count(*) AS `2`, sum(log_visit.visit_total_actions) AS `3`, max(log_visit.visit_total_actions)
AS `4`, sum(log_visit.visit_total_time) AS `5`, sum(case log_visit.visit_total_actions when 1 then 1
when 0 then 1 else 0 end) AS `6`, sum(case log_visit.visit_goal_converted when 1 then 1 else 0 end)
AS `7`, count(distinct log_visit.user_id) AS `39` FROM matomo_log_visit AS log_visit WHERE
log_visit.visit_last_action_time >= ? AND log_visit.visit_last_action_time <= ?
AND log_visit.idsite IN (?) [] {"class":"VisitsSummary","request_id":6046}
[2018-08-22 18:19:34] piwik.DEBUG: PluginsArchiver::callAggregateAllPlugins: Initializing
archiving process for all plugins [visits = 22691, visits converted = 0]
["callAggregateAllPlugins","22691","0"] {"class":"VisitsSummary","request_id":6046}
[2018-08-22 18:19:34] piwik.DEBUG: PluginsArchiver::callAggregateAllPlugins: Archiving day
reports for plugin 'ExamplePlugin'. ["callAggregateAllPlugins","ExamplePlugin"]
[2018-08-22 18:19:34] piwik.DEBUG: PluginsArchiver::callAggregateAllPlugins: Memory delta: 0 M
while archiving day reports for plugin 'ExamplePlugin' (for segment = ''). ["callAggregateAllPlugins",
"Memory delta: 0 M","day","ExamplePlugin","(for segment = '')"] {"class":"VisitsSummary","request_id":6046}
reports for plugin 'Actions'. ["callAggregateAllPlugins","Actions"]
[2018-08-22 18:19:34] piwik.DEBUG: /* trigger = CronArchive */ SELECT log_action.name, log_action.type,
log_action.idaction, log_action.url_prefix, count(distinct log_link_visit_action.idvisit) as `2`,
count(distinct log_link_visit_action.idvisitor) as `1`, count(*) as `12`,
sum( case when custom_float is null then 0 else custom_float end ) / 1000 as `30`,
sum( case when custom_float is null then 0 else 1 end ) as `31`, min(custom_float) / 1000 as `32`,
max(custom_float) / 1000 as `33`, CASE WHEN (MAX(log_link_visit_action.custom_var_v5) = 0
AND log_link_visit_action.custom_var_k5 = '_pk_scount') THEN 1 ELSE 0 END AS `28`,
SUM( CASE WHEN log_action_name_ref.type = 8 THEN 1 ELSE 0 END) AS `29`
FROM matomo_log_link_visit_action AS log_link_visit_action LEFT JOIN matomo_log_action
AS log_action ON log_link_visit_action.%s = log_action.idaction LEFT JOIN matomo_log_action
AS log_action_name_ref ON log_link_visit_action.idaction_name_ref = log_action_name_ref.idaction
WHERE log_link_visit_action.server_time >= ? AND log_link_visit_action.server_time <= ?
AND log_link_visit_action.idsite = ? AND log_link_visit_action.%s IS NOT NULL
AND log_link_visit_action.idaction_event_category IS NULL GROUP BY log_action.idaction
ORDER BY `12` DESC, name ASC [] {"class":"Actions","request_id":6046}
[2018-08-22 18:19:37] piwik.DEBUG: /* trigger = CronArchive */ SELECT log_action.name,
log_action.type, log_action.idaction, log_action.url_prefix,
count(*) as `12`, sum( case when custom_float is null then 0 else custom_float end ) / 1000 as `30`,
SUM( CASE WHEN log_action_name_ref.type = 8 THEN 1 ELSE 0 END) AS `29` FROM matomo_log_link_visit_action
AS log_link_visit_action LEFT JOIN matomo_log_action AS log_action ON log_link_visit_action.%s = log_action.idaction
LEFT JOIN matomo_log_action AS log_action_name_ref ON
AND log_link_visit_action.idsite = ? AND log_link_visit_action.%s IS NOT NULL AND log_link_visit_action.id
