Same problem here, see logs with ‘-vvv’:
Exception trace:
() at /home/analytics.mydomain.com/public_html/core/CronArchive.php:572
Piwik\CronArchive->logFatalError() at /home/analytics.mydomain.com/public_html/core/CronArchive.php:565
Piwik\CronArchive->end() at /home/analytics.mydomain.com/public_html/core/CronArchive.php:318
Piwik\CronArchive->Piwik\{closure}() at /home/analytics.mydomain.com/public_html/core/Access.php:628
Piwik\Access::doAsSuperUser() at /home/analytics.mydomain.com/public_html/core/CronArchive.php:319
Piwik\CronArchive->main() at /home/analytics.mydomain.com/public_html/plugins/CoreConsole/Commands/CoreArchiver.php:27
Piwik\Plugins\CoreConsole\Commands\CoreArchiver->execute() at /home/analytics.mydomain.com/public_html/vendor/symfony/console/Symfony/Component/Console/Command/Command.php:257
Symfony\Component\Console\Command\Command->run() at /home/analytics.mydomain.com/public_html/vendor/symfony/console/Symfony/Component/Console/Application.php:874
Symfony\Component\Console\Application->doRunCommand() at /home/analytics.mydomain.com/public_html/vendor/symfony/console/Symfony/Component/Console/Application.php:195
Symfony\Component\Console\Application->doRun() at n/a:n/a
call_user_func() at /home/analytics.mydomain.com/public_html/core/Console.php:98
Piwik\Console->Piwik\{closure}() at /home/analytics.mydomain.com/public_html/core/Access.php:628
Piwik\Access::doAsSuperUser() at /home/analytics.mydomain.com/public_html/core/Console.php:99
Piwik\Console->doRun() at /home/analytics.mydomain.com/public_html/vendor/symfony/console/Symfony/Component/Console/Application.php:126
Symfony\Component\Console\Application->run() at /home/analytics.mydomain.com/public_html/console:27
DEBUG [2019-03-20 08:59:37] 92010 UserSynchronizer::makeConfigured(): LDAP access synchronization not enabled.
DEBUG [2019-03-20 08:59:37] 92010 UserSynchronizer::makeConfigured: configuring with defaultSitesWithViewAccess =
INFO [2019-03-20 08:59:37] 92010 ---------------------------
INFO [2019-03-20 08:59:37] 92010 INIT
INFO [2019-03-20 08:59:37] 92010 Running Matomo 3.9.0 as Super User
INFO [2019-03-20 08:59:37] 92010 NOTES
INFO [2019-03-20 08:59:37] 92010 - If you execute this script at least once per hour (or more often) in a crontab, you may disable 'Browser trigger archiving' in Matomo UI > Settings > General Settings.
INFO [2019-03-20 08:59:37] 92010 See the doc at: https://matomo.org/docs/setup-auto-archiving/
INFO [2019-03-20 08:59:37] 92010 - Reports for today will be processed at most every 900 seconds. You can change this value in Matomo UI > Settings > General Settings.
INFO [2019-03-20 08:59:37] 92010 - Reports for the current week/month/year will be requested at most every 3600 seconds.
INFO [2019-03-20 08:59:37] 92010 - Will process 1 other websites because some old data reports have been invalidated (eg. using the Log Import script or the InvalidateReports plugin) , IDs: 7
INFO [2019-03-20 08:59:37] 92010 START
INFO [2019-03-20 08:59:37] 92010 Starting Matomo reports archiving...
INFO [2019-03-20 08:59:37] 92010 Old report was invalidated for website id 7
INFO [2019-03-20 08:59:37] 92010 Will pre-process for website id = 7, period = day, date = last22
INFO [2019-03-20 08:59:37] 92010 - pre-processing all visits
DEBUG [2019-03-20 08:59:37] 92010 /usr/bin/php7.3 -q /home/analytics.mydomain.com/public_html/console climulti:request -q --matomo-domain='analytics.mydomain.com' --superuser 'module=API&method=API.get&idSite=7&period=day&date=last22&format=php&trigger=archivephp&pid=42a0a86e2248da8f2bea421214ebb9e7c6a5cd7868f027e38a73c591308c297aa79e8b33d7e7bb5659ceeab855ef1d9f45ed0&runid=92010' > /home/analytics.mydomain.com/public_html/tmp/climulti/42a0a86e2248da8f2bea421214ebb9e7c6a5cd7868f027e38a73c591308c297aa79e8b33d7e7bb5659ceeab855ef1d9f45ed0.output 2>&1 &
WARNING [2019-03-20 08:59:42] 92010 /home/analytics.mydomain.com/public_html/core/Common.php(271): Notice - unserialize(): Error at offset 0 of 109777 bytes - Matomo 3.9.0 - Please report this message in the Matomo forums: https://forum.matomo.org (please do a search first as it might have been reported already)
INFO [2019-03-20 08:59:42] 92010 - tracking data found for website id 11 since 2019-03-19 23:00:00 UTC (since midnight)
INFO [2019-03-20 08:59:42] 92010 Will pre-process for website id = 11, period = day, date = last22
INFO [2019-03-20 08:59:42] 92010 - pre-processing all visits
DEBUG [2019-03-20 08:59:42] 92010 /usr/bin/php7.3 -q /home/analytics.mydomain.com/public_html/console climulti:request -q --matomo-domain='analytics.mydomain.com' --superuser 'module=API&method=API.get&idSite=11&period=day&date=last22&format=php&trigger=archivephp&pid=54db474dfac08017600e1f987b915a428292fe473e4c08abeb093923c2cc15cee39696cafba487c33af463c3494a9a0405af0&runid=92010' > /home/analytics.mydomain.com/public_html/tmp/climulti/54db474dfac08017600e1f987b915a428292fe473e4c08abeb093923c2cc15cee39696cafba487c33af463c3494a9a0405af0.output 2>&1 &
WARNING [2019-03-20 08:59:46] 92010 /home/analytics.mydomain.com/public_html/core/Common.php(271): Notice - unserialize(): Error at offset 0 of 110411 bytes - Matomo 3.9.0 - Please report this message in the Matomo forums: https://forum.matomo.org (please do a search first as it might have been reported already)
INFO [2019-03-20 08:59:46] 92010 Done archiving!
INFO [2019-03-20 08:59:46] 92010 ---------------------------
INFO [2019-03-20 08:59:46] 92010 SUMMARY
INFO [2019-03-20 08:59:46] 92010 Total visits for today across archived websites: 0
INFO [2019-03-20 08:59:46] 92010 Archived today's reports for 0 websites
INFO [2019-03-20 08:59:46] 92010 Archived week/month/year for 0 websites
INFO [2019-03-20 08:59:46] 92010 Skipped 2 websites
INFO [2019-03-20 08:59:46] 92010 - 0 skipped because no new visit since the last script execution
INFO [2019-03-20 08:59:46] 92010 - 0 skipped because existing daily reports are less than 900 seconds old
INFO [2019-03-20 08:59:46] 92010 - 0 skipped because existing week/month/year periods reports are less than 3600 seconds old
INFO [2019-03-20 08:59:46] 92010 - 2 skipped because got an error while querying reporting API
INFO [2019-03-20 08:59:46] 92010 Total API requests: 0
INFO [2019-03-20 08:59:46] 92010 done: 0/2 0%, 0 vtoday, 0 wtoday, 0 wperiods, 0 req, 8669 ms, 2 errors.
INFO [2019-03-20 08:59:46] 92010 Time elapsed: 8.669s
INFO [2019-03-20 08:59:46] 92010 SCHEDULED TASKS
DEBUG [2019-03-20 08:59:46] 92010 26 scheduled tasks loaded
INFO [2019-03-20 08:59:46] 92010 Starting Scheduled tasks...
DEBUG [2019-03-20 08:59:46] 92010 Executing tasks with priority 0:
DEBUG [2019-03-20 08:59:46] 92010 Executing tasks with priority 1:
DEBUG [2019-03-20 08:59:46] 92010 Executing tasks with priority 2:
DEBUG [2019-03-20 08:59:46] 92010 Executing tasks with priority 3:
DEBUG [2019-03-20 08:59:46] 92010 Executing tasks with priority 4:
DEBUG [2019-03-20 08:59:46] 92010 Executing tasks with priority 5:
DEBUG [2019-03-20 08:59:46] 92010 Executing tasks with priority 6:
DEBUG [2019-03-20 08:59:46] 92010 Executing tasks with priority 7:
DEBUG [2019-03-20 08:59:46] 92010 Executing tasks with priority 8:
DEBUG [2019-03-20 08:59:46] 92010 Executing tasks with priority 9:
DEBUG [2019-03-20 08:59:46] 92010 Executing tasks with priority 10:
DEBUG [2019-03-20 08:59:46] 92010 Executing tasks with priority 11:
DEBUG [2019-03-20 08:59:46] 92010 Executing tasks with priority 12:
INFO [2019-03-20 08:59:46] 92010 SUMMARY OF ERRORS
INFO [2019-03-20 08:59:46] 92010 Error: Empty or invalid response '[2019-03-20 08:59:38] piwik.DEBUG: Loaded plugins: CorePluginsAdmin, CoreAdminHome, CoreHome,
WebsiteMeasurable, IntranetMeasurable, Diagnostics, CoreVisualizations, Proxy, API, ExamplePlugin, Widgetize, Transitions, LanguagesManager, Actions, Dashboard, MultiSites, Referrers, UserLanguage, DevicesDetection, Goals, Ecommerce, SEO, Events, UserCountry, GeoIp2, VisitsSummary, VisitFrequency, VisitTime, VisitorInterest, ExampleAPI, RssWidget, Feedback, Monolog, TwoFactorAuth, UsersManager, SitesManager, Installation, CoreUpdater, CoreConsole, ScheduledReports, UserCountryMap,
Live, CustomVariables, PrivacyManager, ImageGraph, Annotations, MobileMessaging, Overlay, SegmentEditor, Insights, Morpheus, Contents, BulkTracking, Resolution, DevicePlugins, Heartbeat, Intl, Marketplace, ProfessionalServices, UserId, CustomPiwikJs, LoginLdap [] {"class":"Piwik\\Plugin\\Manager","request_id":92101} [2019-03-20 08:59:38] piwik.DEBUG: UserSynchronizer::makeConfigured(): LDAP access synchronization not enabled. {"func":"makeConfigured"} {"class":"LoginLdap","request_id":92101} [2019-03-20 08:59:38] piwik.DEBUG: UserSynchronizer::makeConfigured: configuring with defaultSitesWithViewAccess = {"func":"makeConfigured","sites":""} {"class":"LoginLdap","request_id":92101} [2019-03-20 08:59:38] piwik.DEBUG: /* trigger = CronArchive */ SELECT count(distinct log_visit.idvisitor) AS `1`, count(*) AS `2`, sum(log_visit.visit_total_actions) AS `3`, max(log_visit.visit_total_actions) AS `4`, sum(log_visit.visit_total_time) AS `5`,
sum(case log_visit.visit_total_actions when 1 then 1 when 0 then 1 else 0 end) AS `6`, sum(case log_visit.visit_goal_converted when 1 then 1 else 0 end) AS `7`, count(distinct log_visit.user_id) AS `39` FROM matomo_log_visit AS log_visit WHERE log_visit.visit_last_action_time >= ? AND log_visit.visit_last_action_time <= ? AND log_visit.idsite IN (?) [] {"class":"VisitsSummary","request_id":92101} [2019-03-20 08:59:38] piwik.DEBUG: PluginsArchiver::callAggregateAllPlugins: Initializing archiving process for all plugins [visits = 3, visits converted = 0] ["callAggregateAllPlugins",3,"0"] {"class":"VisitsSummary","request_id":92101} [2019-03-20 08:59:38] piwik.DEBUG: PluginsArchiver::callAggregateAllPlugins: Archiving day reports for plugin 'ExamplePlugin'. ["callAggregateAllPlugins","ExamplePlugin"] {"class":"VisitsSummary","request_id":92101} [2019-03-20 08:59:38] piwik.DEBUG: PluginsArchiver::callAggregateAllPlugins: Memory
delta: 400 B while archiving day reports for plugin 'ExamplePlugin' (for segment = ''). ["callAggregateAllPlugins","Memory delta: 400 B","day","ExamplePlugin","(for segment = '')"] {"class":"VisitsSummary","request_id":92101} [2019-03-20 08:59:38] piwik.DEBUG: PluginsArchiver::callAggregateAllPlugins: Archiving day reports for plugin 'Actions'. ["callAggregateAllPlugins","Actions"] {"class":"VisitsSummary","request_id":92101} [2019-03-20 08:59:38] piwik.DEBUG: /* trigger = CronArchive */ SELECT log_action.name, log_action.type, log_action.idaction, log_action.url_prefix, count(distinct log_link_visit_action.idvisit) as `2`, count(distinct log_link_visit_action.idvisitor) as `1`, count(*) as `12`, sum( case when custom_float is null then 0 else custom_float end ) / 1000 as `30`, sum(
case when custom_float is null then 0 else 1 end ) as `31`,
min(custom_float) / 1000 as `32`, max(custom_float) / 1000 as `33`, CASE WHEN (MAX(log_link_visit_action.custom_var_v5) = 0 AND log_link_visit_action.custom_var_k5 = '_pk_scount') THEN 1 ELSE 0 END AS `28`, SUM( CASE WHEN log_action_name_ref.type = 8 THEN 1 ELSE 0 END) AS `29` FROM matomo_log_link_visit_action AS log_link_visit_action LEFT JOIN matomo_log_action AS log_action ON log_link_visit_action.%s = log_action.idaction LEFT JOIN matomo_log_action AS log_action_name_ref ON log_link_visit_action.idaction_name_ref = log_action_name_ref.idaction WHERE log_link_visit_action.server_time >= ? AND log_link_visit_action.server_time <= ? AND log_link_visit_action.idsite IN (?) AND log_link_visit_action.%s IS NOT NULL AND log_link_visit_action.idaction_event_category IS NULL GROUP BY log_link_visit_action.%s ORDER BY `12` DESC, name ASC [] {"class":"Actions","request_id":92101} [2019-03-20 08:59:38] piwik.DEBUG: /* trigger = CronArchive */ SELECT log_action.name, log_action.type, log_action.idaction, log_action.url_prefix, count(distinct log_link_visit_action.idvisit) as `2`, count(distinct log_link_visit_action.idvisitor) as `1`, count(*) as `12`, sum( case when custom_float is null
then 0 else custom_float end ) / 1000 as `30`, sum( case when custom_float is null then 0 else 1 end ) as `31`, min(custom_float) / 1000 as `32`, max(custom_float) / 1000 as `33`, CASE WHEN (MAX(log_link_visit_action.custom_var_v5) = 0 AND log_link_visit_action.custom_var_k5 = '_pk_scount') THEN 1 ELSE 0 END AS `28`, SUM( CASE WHEN log_action_name_ref.type = 8
INFO [2019-03-20 08:59:46] 92010 Error: Empty or invalid response '[2019-03-20 08:59:43] piwik.DEBUG: Loaded plugins: CorePluginsAdmin, CoreAdminHome, CoreHome,
Live, CustomVariables, PrivacyManager, ImageGraph, Annotations, MobileMessaging, Overlay, SegmentEditor, Insights, Morpheus, Contents, BulkTracking, Resolution, DevicePlugins, Heartbeat, Intl, Marketplace, ProfessionalServices, UserId, CustomPiwikJs, LoginLdap [] {"class":"Piwik\\Plugin\\Manager","request_id":92215} [2019-03-20 08:59:43] piwik.DEBUG: UserSynchronizer::makeConfigured(): LDAP access synchronization not enabled. {"func":"makeConfigured"} {"class":"LoginLdap","request_id":92215} [2019-03-20 08:59:43] piwik.DEBUG: UserSynchronizer::makeConfigured: configuring with defaultSitesWithViewAccess = {"func":"makeConfigured","sites":""} {"class":"LoginLdap","request_id":92215} [2019-03-20 08:59:43] piwik.DEBUG: /* trigger = CronArchive */ SELECT count(distinct log_visit.idvisitor) AS `1`, count(*) AS `2`, sum(log_visit.visit_total_actions) AS `3`, max(log_visit.visit_total_actions) AS `4`, sum(log_visit.visit_total_time) AS `5`,
sum(case log_visit.visit_total_actions when 1 then 1 when 0 then 1 else 0 end) AS `6`, sum(case log_visit.visit_goal_converted when 1 then 1 else 0 end) AS `7`, count(distinct log_visit.user_id) AS `39` FROM matomo_log_visit AS log_visit WHERE log_visit.visit_last_action_time >= ? AND log_visit.visit_last_action_time <= ? AND log_visit.idsite IN (?) [] {"class":"VisitsSummary","request_id":92215} [2019-03-20 08:59:43] piwik.DEBUG: PluginsArchiver::callAggregateAllPlugins: Initializing archiving process for all plugins [visits = 1, visits converted = 0] ["callAggregateAllPlugins",1,"0"] {"class":"VisitsSummary","request_id":92215} [2019-03-20 08:59:43] piwik.DEBUG: PluginsArchiver::callAggregateAllPlugins: Archiving day reports for plugin 'ExamplePlugin'. ["callAggregateAllPlugins","ExamplePlugin"] {"class":"VisitsSummary","request_id":92215} [2019-03-20 08:59:43] piwik.DEBUG: PluginsArchiver::callAggregateAllPlugins: Memory
delta: 400 B while archiving day reports for plugin 'ExamplePlugin' (for segment = ''). ["callAggregateAllPlugins","Memory delta: 400 B","day","ExamplePlugin","(for segment = '')"] {"class":"VisitsSummary","request_id":92215} [2019-03-20 08:59:43] piwik.DEBUG: PluginsArchiver::callAggregateAllPlugins: Archiving day reports for plugin 'Actions'. ["callAggregateAllPlugins","Actions"] {"class":"VisitsSummary","request_id":92215} [2019-03-20 08:59:43] piwik.DEBUG: /* trigger = CronArchive */ SELECT log_action.name, log_action.type, log_action.idaction, log_action.url_prefix, count(distinct log_link_visit_action.idvisit) as `2`, count(distinct log_link_visit_action.idvisitor) as `1`, count(*) as `12`, sum( case when custom_float is null then 0 else custom_float end ) / 1000 as `30`, sum(
min(custom_float) / 1000 as `32`, max(custom_float) / 1000 as `33`, CASE WHEN (MAX(log_link_visit_action.custom_var_v5) = 0 AND log_link_visit_action.custom_var_k5 = '_pk_scount') THEN 1 ELSE 0 END AS `28`, SUM( CASE WHEN log_action_name_ref.type = 8 THEN 1 ELSE 0 END) AS `29` FROM matomo_log_link_visit_action AS log_link_visit_action LEFT JOIN matomo_log_action AS log_action ON log_link_visit_action.%s = log_action.idaction LEFT JOIN matomo_log_action AS log_action_name_ref ON log_link_visit_action.idaction_name_ref = log_action_name_ref.idaction WHERE log_link_visit_action.server_time >= ? AND log_link_visit_action.server_time <= ? AND log_link_visit_action.idsite IN (?) AND log_link_visit_action.%s IS NOT NULL AND log_link_visit_action.idaction_event_category IS NULL GROUP BY log_link_visit_action.%s ORDER BY `12` DESC, name ASC [] {"class":"Actions","request_id":92215} [2019-03-20 08:59:43] piwik.DEBUG: /* trigger = CronArchive */ SELECT log_action.name, log_action.type, log_action.idaction, log_action.url_prefix, count(distinct log_link_visit_action.idvisit) as `2`, count(distinct log_link_visit_action.idvisitor) as `1`, count(*) as `12`, sum( case when custom_float is null
