Running php /usr/bin/php /var/www/piwik/console core:archive --url=http://ccccc.do.main/ > /tmp/matomo-archive.log
i receive the following result from CRON
The drive has plenty of space to create new tables;
3002 Got invalid response from API request: ?module=API&method=API.get&idSite=1&period=day&date=last2&format=php&trigger=archivephp. Response was 'a:2:{s:6:"result";s:5:"error";s:7:"message";s:17293:"Mysqli statement execute error : Can't create table 'piwik_logtmpsegmenta9bbc6446e763e1311bac6beda8eeb75' (errno: 13) - in plugin Goals - in plugin Goals #0 /var/www/piwik/core/ArchiveProcessor/Loader.php(165): Piwik\ArchiveProcessor\PluginsArchiver->callAggregateAllPlugins(3077, '0', false) #1 /var/www/piwik/core/ArchiveProcessor/Loader.php(111): Piwik\ArchiveProcessor\Loader->prepareAllPluginsArchive(3077, '0') #2 /var/www/piwik/core/ArchiveProcessor/Loader.php(84): Piwik\ArchiveProcessor\Loader->prepareArchiveImpl('VisitsSummary') #3 /var/www/piwik/core/Context.php(75): Piwik\ArchiveProcessor\Loader->Piwik\ArchiveProcessor\{closure}() #4 /var/www/piwik/core/ArchiveProcessor/Loader.php(85): Piwik\Context::changeIdSite(1, Object(Closure)) #5 /var/www/piwik/core/Archive.php(803): Piwik\ArchiveProcessor\Loader->prepareArchive('VisitsSummary') #6 /var/www/piwik/core/Archive.php(607): Piwik\Archive->prepareArchive(Array, Object(Piwik\Site), Object(Piwik\Period\Day)) #7 /var/www/piwik/core/Archive.php(551): Piwik\Archive->cacheArchiveIdsAfterLaunching(Array, Array) #8 /var/www/piwik/core/Archive.php(480): Piwik\Archive->getArchiveIds(Array) #9 /var/www/piwik/core/Archive.php(295): Piwik\Archive->get(Array, 'numeric') #10 /var/www/piwik/plugins/VisitsSummary/API.php(36): Piwik\Archive->getDataTableFromNumeric(Array) #11 [internal function]: Piwik\Plugins\VisitsSummary\API->get('1', 'day', 'last2', false, Array) #12 /var/www/piwik/core/API/Proxy.php(237): call_user_func_array(Array, Array) #13 /var/www/piwik/core/Context.php(28): Piwik\API\Proxy->Piwik\API\{closure}() #14 /var/www/piwik/core/API/Proxy.php(328): Piwik\Context::executeWithQueryParameters(Array, Object(Closure)) #15 /var/www/piwik/plugins/API/API.php(437): Piwik\API\Proxy->call('\\Piwik\\Plugins\\...', 'get', Array) #16 [internal function]: Piwik\Plugins\API\API->get('1', 'day', 'last2', false, Array) #17 /var/www/piwik/core/API/Proxy.php(237): call_user_func_array(Array, Array) #18 /var/www/piwik/core/Context.php(28): Piwik\API\Proxy->Piwik\API\{closure}() #19 /var/www/piwik/core/API/Proxy.php(328): Piwik\Context::executeWithQueryParameters(Array, Object(Closure)) #20 /var/www/piwik/core/API/Request.php(266): Piwik\API\Proxy->call('\\Piwik\\Plugins\\...', 'get', Array) #21 /var/www/piwik/plugins/API/Controller.php(41): Piwik\API\Request->process() #22 [internal function]: Piwik\Plugins\API\Controller->index() #23 /var/www/piwik/core/FrontController.php(590): call_user_func_array(Array, Array) #24 /var/www/piwik/core/FrontController.php(165): Piwik\FrontController->doDispatch('API', false, Array) #25 /var/www/piwik/core/dispatch.php(34): Piwik\FrontController->dispatch() #26 /var/www/piwik/index.php(27): require_once('/var/www/piwik/...') #27 /var/www/piwik/core/CliMulti/RequestCommand.php(79): require_once('/var/www/piwik/...') #28 /var/www/piwik/vendor/symfony/console/Symfony/Component/Console/Command/Command.php(257): Piwik\CliMulti\RequestCommand->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput)) #29 /var/www/piwik/vendor/symfony/console/Symfony/Component/Console/Application.php(874): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput)) #30 /var/www/piwik/vendor/symfony/console/Symfony/Component/Console/Application.php(195): Symfony\Component\Console\Application->doRunCommand(Object(Piwik\CliMulti\RequestCommand), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput)) #31 [internal function]: Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput)) #32 /var/www/piwik/core/Console.php(140): call_user_func(Array, Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput)) #33 /var/www/piwik/core/Access.php(644): Piwik\Console->Piwik\{closure}() #34 /var/www/piwik/core/Console.php(141): Piwik\Access::doAsSuperUser(Object(Closure)) #35 /var/www/piwik/core/Console.php(93): Piwik\Console->doRunImpl(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput)) #36 /var/www/piwik/vendor/symfony/console/Symfony/Component/Console/Application.php(126): Piwik\Console->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput)) #37 /var/www/piwik/console(32): Symfony\Component\Console\Application->run() #38 {main}, caused by: Mysqli statement execute error : Can't create table 'piwik_logtmpsegmenta9bbc6446e763e1311bac6beda8eeb75' (errno: 13) - in plugin Goals #0 /var/www/piwik/core/ArchiveProcessor/Loader.php(165): Piwik\ArchiveProcessor\PluginsArchiver->callAggregateAllPlugins(1412, 0, false) #1 /var/www/piwik/core/ArchiveProcessor/Loader.php(111): Piwik\ArchiveProcessor\Loader->prepareAllPluginsArchive(1412, 0) #2 /var/www/piwik/core/ArchiveProcessor/Loader.php(84): Piwik\ArchiveProcessor\Loader->prepareArchiveImpl('Goals') #3 /var/www/piwik/core/Context.php(75): Piwik\ArchiveProcessor\Loader->Piwik\ArchiveProcessor\{closure}() #4 /var/www/piwik/core/ArchiveProcessor/Loader.php(85): Piwik\Context::changeIdSite(1, Object(Closure)) #5 /var/www/piwik/core/ArchiveProcessor.php(664): Piwik\ArchiveProcessor\Loader->prepareArchive('Goals') #6 /var/www/piwik/plugins/Goals/Archiver.php(92): Piwik\ArchiveProcessor->processDependentArchive('Goals', 'visitorType%3D%...') #7 /var/www/piwik/core/Plugin/Archiver.php(89): Piwik\Plugins\Goals\Archiver->aggregateDayReport() #8 /var/www/piwik/core/ArchiveProcess
ERROR [2020-04-30 13:05:03] 3002 Empty or invalid response '' for website id 1, Time elapsed: 1.642s, skipping
