Nvizn
1
I’m having problems while attempting to auto archive. Here’s the syntax:
su user -c "usr/bin/php /my/location/piwik/console core:archive --url=https://mywebsite.com/"
or
sudo su user -c "usr/bin/php /my/location/piwik/console core:archive --url=https://mywebsite.com/"
Results:
[InvalidArgumentException]
There are no commands defined in the "core" namespace.
Any insight and assistance, is greatly appreciated!
Nvizn
2
Hmm… Anyone? No one out there, using this feature?
http://piwik.org/docs/setup-auto-archiving/
matthieu
(Matthieu Aubry)
3
It should work, can you try with latest beta? I would like to test early beta and RC releases, how do I enable automatic updates to use these development versions? - Analytics Platform - Matomo
Note that it will only work after piwik has been installed and the file config/config.ini.php is found
Nvizn
4
How is the location of config.ini.php, defined in Piwik?
Currently, it is found:
/usr/local/web/htdocs/website/config/config.ini.php
