I’ve created a private Piwik RPM that includes my DB configuration and automatically gets installed on a new instance. As a part of the init script of each instance, the GeoIP PECL extension is also installed.
When I log into Piwik for the first time, GeoIP/PECL is marked as installed and available, but not as selected.
I don’t see anything in config/config.ini.php (before or after manually selecting GeoIP/PECL) that would suggest GeoIP/PECL is enabled.
Is there any way to make GeoIP/PECL the default via configuration files?
