Hello There i am using Matomo version 3.13.4 with PHP 7.2 and everytime i start the archive job console core:archive i get the message
WARNING [2020-04-14 15:05:48] 26490 /srv/www/matomo/core/Common.php(297): Notice - unserialize(): Error at offset 0 of 5143 bytes - Matomo 3.13.4 - Please report this message in the Matomo forums: https://forum.matomo.org (please do a search first as it might have been reported already)
ERROR [2020-04-14 15:05:48] 26490 Empty or invalid response 'PHP Notice: Undefined index: class in /srv/www/matomo/plugins/Monolog/Formatter/LineMessageFormatter.php on line 87 PHP Notice: Undefined index: type in /srv/www/matomo/plugins/Monolog/Formatter/LineMessageFormatter.php on line 87 PHP Notice: Undefined index: class in /srv/www/matomo/plugins/Monolog/Formatter/LineMessageFormatter.php on line 87 PHP Notice: Undefined index: type in /srv/www/matomo/plugins/Monolog/Formatter/LineMessageFormatter.php on line 87
Things i tried
Clearing Cache
Checked Config files and updated them to new Versions
Went through ISSUE 14229
Applied Patch from there Patch
But all of that didnt fixed the Problem.
OS is rhel 7.8
If there is more information needed please don’t hesitate to ask
This is fascinating. It seems like there is some error occurring during archving and when printing the error message a second error occurs (Undefined index: class).
You could try to replace this line with
$levelTrace = '';
so that the first error message is displayed properly.
Thanks for the response the process went now through only with ah few warnings.
/srv/www/matomo/vendor/composer/ClassLoader.php(444): Warning - include(/srv/www/matomo/vendor/composer/../../plugins/ExamplePlugin/Archiver.php): failed to open stream: No such file or directory - Matomo 3.13.4 - Please report this message in the Matomo forums: https://forum.matomo.org (please do a search first as it might have been reported already)
WARNING [2020-04-15 05:25:46] 11460 /srv/www/matomo/vendor/composer/ClassLoader.php(444): Warning - include(): Failed opening '/srv/www/matomo/vendor/composer/../../plugins/ExamplePlugin/Archiver.php' for inclusion (include_path='/srv/www/matomo/vendor/pear/pear_exception:/srv/www/matomo/vendor/pear/console_getopt:/srv/www/matomo/vendor/pear/pear-core-minimal/src:/srv/www/matomo/vendor/pear/archive_tar:.:/usr/share/pear:/usr/share/php') - Matomo 3.13.4 - Please report this message in the Matomo forums: https://forum.matomo.org (please do a search first as it might have been reported already)
This is really weird.
Can you check the integrity checker to see if there are files remaining that should not be there? And can you check the plugin list if ExamplePlugin is there and enabled? It should be deleted since a few Matomo releases, but it seems like archiving tries to read a file from this plugin and fails.
Hey there thanks for the answer,
I disabled the Plugin and now there are no warnings etc.
Everything works now fluently.
Is this an issue wich can affect more people or do you think this issue is uniqe?
If you would like me to i can send you more logfiles for investigation.
:UPDATE --> I now went back to the original configuration in the linemessageformatter and the process of archiving went through without any errors
Eurgh, I came across this post because I use configuration management to manage this file and so ExampleAPI and ExamplePlugin were still in the settings files. Removing these led to the issues reported here disappearing.
