I’ve just checked for my disk space usage and found out that its reporting the metric “done” being using most of the space.
What is that metric about? If its not useful … can I do something about it?
Thanks,
Thomas
Thanks,
Thomas
Where do you see this view? I don’t know a database table called done
in Matomo. Or am I misunderstanding your issue.
It shown in “Database Usage” under “Diagnostics” as a “Metric”, not a specific table.
See the bigger screenshot below
Does anyone have any ideas?
I found it in the numeric tables, might be because of a couple thousand sites in piwik and that is stored at least for each day.
Can I delete the ones more than a year ago possibly?
Or will it try to reprocess?
Thanks,
Thomas
I am not sure what the done
is exactly, but it is taking the largest amount of space in my instance
Delete old archived reports
in the Anonymize data
settings should be what you want.
Just keep in mind that if you don’t have the raw visitor logs anymore, the data is lost.
Thanks but I have it setup like that and funny enough especially the done entries are not (all?) being deleted.
