And ONLY in the case if the user wants to have ADDITIONALLY classes he has to define his own (which can override the standard like ‘piwik_link’ [see below])?
For example:
piwikTracker.setIgnoreClasses( [“no-tracking”] );
where ‘no-tracking’ is also known by piwik?
But as it said ‘classes’ i could add my own classes like:
Otherhwise it should be: piwikTracker.setIgnoreClass(["…"]); (only a single (1) definition)
Am i right?
Or - when i go further with the documentation, it says:
setLinkClass( string ) - Set outlink class name (i.e., override default: piwik_link)
or:
Note: you can customize and rename the CSS class used to force a click to being recorded as an outlink:
piwikTracker.setLinkClass( “external” );
this will replace the standard ‘piwik_link’?
Same here: setDownloadClass( string ) - Set download class name (i.e., override default: piwik_download)
No, it is in addition to.
QUOTE
For example:
Otherhwise it should be: piwikTracker.setIgnoreClass([“…”]); (only a single (1) definition]Or - when i go further with the documentation, it says:
or:
Once you say ’ … in addition …’, but then you agree when i say that it will be REPLACED (and as it is in the documentation):
[quote=vipsoft @ Jun 14 2009, 02:52 AM]piwikTracker.setLinkClass( “external” );
Same here: setDownloadClass( string ) - Set download class name (i.e., override default: piwik_download)[/quote]
So, when i take ‘piwik_link’: can i define additonal (css) classes OR will this be overridden when i define my own with piwikTracker.setLinkClass( “here_the_class_name” );
