Hi all
Quick Q for you: is there an expectation as to when the Docker for Matomo 4.5.0 will be available?
Alternatively, may I create a PR to update the existing Dockerfile to 4.5.0?
Thanks!
Hi all
Thanks!
I am not fully familiar with how building the container works, but I think all of the work has been done in https://github.com/matomo-org/docker/commit/0b7d82b64d57a6ff321c635eaf9c20746e012e12
and the part that needs to be done by the docker team has been merged in
https://github.com/docker-library/official-images/pull/11051
So the only thing remaining is for the docker team to build the image and this seems to have happened 5min ago:
https://hub.docker.com/_/matomo?tab=tags
Hi Lukas
Thanks for that; the pull request has been merged and the Docker image is now downloading.
Cheers!
Justin
